Hello I just got a 200s
Hello everyone i am new to the site and i just bought a 1985 Honda 200s for 40 dollars the other day! I am in the process of fixing it up and i got the motor all together the other day and when i pull it over the motor will turn over once then freezes up until i let the pressure off the pull string and then i can pull it over again and it repeats the process. But when i take the plug out it pulls fine there is no stick point.
Any advice would be greatly appreciated. Thanks
change your plug the piston might be hitting the spark plug cause it ight be alittle to long. i had that problem with my 110 changed the plug and it fired right up
I will definatley try that!
//ArrowChat Integreation Code
