Results 1 to 8 of 8
Thread: First shock rebuild-Rebuilding my monoshock need some help
    Tbcoplin is offline At The Back Of The Pack Arm chair racerFirst time rider
    Oct 2009
    Hammond, la
    157
    Question First shock rebuild-Rebuilding my monoshock need some help
    Ordered a shock seal off eBay. When installing it in the shock cylinder, do I oil the rubber o ring and the cylinder before it Install it? Also, at what point do I istall the shock oil?
    84 Big Red- User
    85 250SX- clean
    85 200X- mint- < 10 hrs on it
    85 350X- Mint- <40 hours on it
    86 350X- mint- <40 hours on it
    2-85 tri-z's- Both frame off restorations
    84 250R- Mint- <15 hours on it
    86 250R- Super clean- < 30 hours on it
    86 500R- Sick fast!!!
    86 Tecate 3- Frame off restoration- Mint
    86 Big Red- Mint- <30 hours on it
    Manitoba
    536
    If you get this figured out, post us a tutorial. I'd like to know how its done. Where did you get the internal parts? For Honda's, the don't seem to list internal components for the rear monoshock. I have a 200x rear mono I'd like to rebuild.
    Oct 2009
    Hammond, la
    157
    eBay had the whole piece that goes n the cylinder. $36 all balls racing. Look at their site . Good luck
    84 Big Red- User
    85 250SX- clean
    Oct 2009
    Hammond, la
    157
    Can anyone help me? Please?
    84 Big Red- User
    85 250SX- clean
    Aug 2007
    Moab, UT
    1,807
    Sounds like you'd be better off taking it to a proffesional.
    Maryland
    3,077
    Shock rebuilding isn't something you can usually do yourself. Even the most technical people on here still go to professionals to get shocks rebuilt. It's just too easy to mess up and create a dangerous situation.
    scottyms's Avatar
    scottyms is offline At The Back Of The Pack Arm chair racerFirst time rider
    Feb 2006
    Shocks arn't that complicated... he's not looking to revalve it just make it not leak i'm assuming....
    there are a few internal parts you should also replace, the seal head is only one part... check the shaft to make sure its not pitted or rusty if it is there's no sense in rebuilding it with out having the shaft rechromed cause it will destroy the new seal... there are a lot of places to get the info your looking for... the factory manual has a pretty good section on rebuilding the rear shock... im assuming this is for your tecate project?
    scotty
    Oct 2009
    Hammond, la
    157
    Yes it is the shock off my 86 tecate. You r right. Just pulled it apart, cleaned it up and wanting to change whatever parts I need to get it working without leaks. The inside cylinder and the shaft are in almost perfect condition. I replaced the part that slides up and down the shaft. What about the piece that is stationary on the end of the shaft? I am unable to fund any parts for that piece. If I put it back together, you think I will be ok?
    84 Big Red- User
    85 250SX- clean
