Results 1 to 11 of 11
Thread: straight pipe
    May 2003
    336
    straight pipe
    what would happen if i ran a staright pip on my 83 ytm200E? thanx alot guys
    kyle
    83 ytm200E SOLD & mid 80 honda 185s
    mywebsite
    http://www.geocities.com/raptor660rrules
    CPSC
    looking for:
    TRI-Z GOOD CONDITION
    several parts for an 83 ytm200E if ya need anything let me know.
    Nov 2001
    B.C.
    933
    It would be way too loud...
    And it would be running lean....
    Join The Trike Registry Now!
    http://fly.to/TrikeHeaven
    May 2003
    Shediac, New Brunswick
    1,126
    re:
    but would it hurt anything???? someone told me that you need back compression for your vavles will burn out...???
    '84 Honda 200x
    slow restro
    kdagenais is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2003
    254
    It will burn out the valves in the long run and will be very loud.
    slippy4 is offline Just Too Addicted Arm chair racerJust too addicted
    May 2003
    556
    it isnt that that loud, when i got my 200x it had strait pipe on it and wasnt too bad, just the neighbors didnt like it too much. but i ran it like that for years and nothing happend
    Southern MN
    1,875
    It dosent make too much diffrance either way. Its not like a 2 stroke, where it needs the expansion chamber and the back pressure. Not having a muffler will give you a headache after while. It would have a little more power with the muffler on tho. Im with Skippy on this one. I rode my 200x for a while without a muffler, and it worked just fine. After I put the muffler on, I wanted to take it back off, because it sounded a lot cooler without it. )
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    May 2003
    556
    yeah, it sounds awesome, but i like the way my DG sounds now
    May 2003
    336
    well im goin to try it. if anything does happen im goin to rebuild it this winter anyway.
    kyle
    mywebsite
    CPSC
    looking for:
    bbechtel16 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Halifax, PA
    400
    Just check your jetting after you remove the silencer and you will be fine.
    -'86 ATC 250SX: No longer mine... Complete 350X front end, Corbra Megaphone system, 350X carb with UNI dual stage foam & outerwear bolted driectly up, Powroll/Rocky 260cc bore 10.5 to 1 compression piston.
    mrman550 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Feb 2003
    226
    will it hurt to run a stright pipe on my 84 tecate??
    SE Minnesota
    533
    you need the back pressure on a two stroke, so you should not use it on a tecate. I believe that you will lose almost all of the low end power.
    83 YT 175
    85 ALT 125
