Results 1 to 3 of 3
Thread: xr70 motor in a 85 atc110??? or any other motor fit??
    May 2009
    east hanover nj
    21
    can i put a newer xr70 motor in a 85 atc110??? please dont answer not enough power...i want to know if the chain /sprockets,motor mounts line up at all????has anyone tried this??? anyone put another motor in a 84-85 atc110 without extreme mods??
    Jul 2008
    MD
    911
    A honda/lifan engine will fit with $15 brackets from DR ATv. You will need to change the counter sprocket to a 428 sprocket to match the rear.
    If the XR70 motor is similar to the honda 50 engine then it will work doing the same thing.
    You will also need a pit bike exhaust or something similar for it.
    May 2009
    east hanover nj
    21
    Quote Originally Posted by 86trizinger View Post
    thanks for the sprocket tip thats an easy fix... i dont see the $15 brackets from DR ATv, do you have a link??? the other thing i dont know if i will be using a lifan engine, i may use a 70 or 50 honda motor with an 88cc kit... anyone have links or pics of atc110 with other motors or links on installing lifan motors?? i think they put lifan motors in ct110s but i dont know if it will work for atc110s..
