Results 1 to 15 of 27
Thread: $2000 to fix my 83' R. What do you think?
    Feb 2005
    Canada
    663
    Question $2000 to fix my 83' R. What do you think?
    I recently brought it to a shop to see what was wrong with it and as i suspected the engine is pretty much beat crank, piston etc. there is already $400 into it to find out what was wrong with it. The total cost including tax would be $2000. What do you think. I could buy another one but could end up back in the same spot again. At least this way ill know it will be done right and will last a long time, plus i already have to pay $400 just to pick it up. Opinions anyone.
    1984 Honda 250R
    1985 ATC 250SX
    1985 Tri-Z 250
    1983 Honda 250R
    1986 Honda 350X
    1983 Yamaha Tri-Moto 175
    1983 Honda Big Red 200
    1981 Honda ATC 110
    Willamstown PA
    5,823
    they on earth is all wrong with it for $2000,they better gold plate that motor. im think your getting ripped. why do you need to pay $400 to pic it up?
    Masshole
    2,191
    Someone is trying to bone you HARD. $400 for them just to break it down enough to find a bad conn. rod is B-S. It is literally a 20 min job to take the jug off. Ask em for the breakdown on what this $400 job entailed. I personally wouldnt pay it, then again I have never brought something to a dealer either.
    newfane ny
    1,277
    i thin i saw a 250 r engine rebuilt on here for $700 with your old one for a core, i think i would go that way and install the engine yourself,its easy to do
    Masshole
    2,191
    A crank re-rodding should be about 150
    bore job and piston under 200
    crank bearings 50
    gaskets 50
    Thats really about it, so long as everything else is good. A decent mechanic should be able to do that whole entire job starting with the whole bike in under 7 hrs so long as everything goes smooth.
    I fail to see how they could possibly come up with 2g's.
    Sep 2008
    845 New York
    2,302
    whats the shop hourly rate?
    1985 Quad Killer
    1985 Mini Raag
    1985 Green Gobbin X2!!
    1990 Kawasaki 300sx
    R.I.P
    Worcester, MA
    1,117
    That's ridiculous. Locally, we have some guys that do free estimates, not $400 estimates (hell, that is more than I PAID for my three wheelers), and that whole job could be done for a few hundred. Tell them if they want to bone men that hard, go to prison.
    Any air cooled engine is a piece of cake. 1,5 hours in and out, unless bolts break..............
    But, they don't budge on 80$ an hour labor and maybe they want 400$ just to rebuild the crank?? Who knows.
    Then there are gaskets/ o- rings and whatever else is still available, maybe 75$??
    Then there is a bore,hone and a piston kit, maybe another 150-200$??
    Main bearings, every tranny bearing (is that in the quote?) another 200$ or so.....
    Couple hours to split and re-assemble.
    400$ to break it down like and merely diagnose the problem like Jeff said is WAY too much...............
    I'd imagine it's closer to about 1000$-1200$ to rebuild that thing back to the 25yo reliability.
    Your crank just needs the rod kit, the halves are good. Any experienced shop can press in that rod pin and true it up in an hour IMHO, but I have seen flat rate charges of about 75$ to replace and true a crank without parts. Then you add the cost of the rod kit.......
    It's tough for you guys. I've won entire NOS 350X motors for 730$, and I know that there apples and oranges. But 2000$ is far high IMHO........
    I'd do as much as I can myself, and let the shop rebuild the crank and bore the cylinder if needed. Not to mention that 2000$ doesn't even blast and PC or paint the cases!!
    You can by a 20 ton press to install bearings for 200$, V blocks for another 15$ and a decent magnetic base indicator setup good enough for what you do for another 50-100$
    I like investing in tools rather than paying for labor myself.....................
    Feb 2005
    Canada
    663
    they put 4 1/2 hrs. into it to break it down. It needs a new crank kit which honda does not make anymore so they found a new crank kit that they can rebuild. The parts alone are 700$ bearings, rings piston bore. There was metal shavings in it so it was pretty beat. That price is a discount to because we bought numerous quads and motorcycles there, a Thundercat last week. At least it should last a long time.
    1984 Honda 250R
    1985 ATC 250SX
    1985 Tri-Z 250
    1983 Honda 250R
    1986 Honda 350X
    1981 Honda ATC 110
    matt86200x's Avatar
    matt86200x is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2009
    Canada Eh!
    366
    where is canada are you haha i had an aircooled 81 250r that was the first engine i ever tore down and rebuilt myself just by using the manual. fairly easy to do
    85 250sx
    86 300es in the making
    86 200x
    86 350x
    Nov 2009
    1,147
    It seems like a crazy amount of time breaking it down. Thats hard to explain. But I guess parts are more in Canada, so maybe a $1200 rebuild is $2000 over there. Does the $2000 include the $400 for just picking it up?
    But if I had the money and was not mechanically inclined I would pay to have the motor professionally rebuilt, instead of getting another one that's going to need work too, might not be long before the other one will need some engine work. Treat it right and you'll get years of trouble free riding on it.
    Feb 2005
    Canada
    663
    ya the 2000 would be the total including the 400 for tear down after taxes. After reading all the posts and estimates for parts I can see how all the things add up but the labor is where half of that is. I guess ill just look at it like im starting from scratch with a whole new engine. Thanks guys.
    1984 Honda 250R
    1985 ATC 250SX
    1985 Tri-Z 250
    1983 Honda 250R
    1986 Honda 350X
    1981 Honda ATC 110
    Willamstown PA
    5,823
    you cant get cranks for air foolers anymore?
    Sep 2007
    100mi west of Chicago
    3,582
    $2000 is a discounted price?
    You could buy a minty fresh liquid R for that, especially in this economy.
    Rob
    Feb 2005
    Canada
    663
    wont find a nice 250 liquid r around here for that. Won't know how long it would last or how much wear and tear it has on it either i guess.
    1984 Honda 250R
    1985 ATC 250SX
    1985 Tri-Z 250
    1983 Honda 250R
    1986 Honda 350X
    1981 Honda ATC 110
