Results 1 to 3 of 3
Thread: Chain and sprocket question
    250sxman is offline At The Back Of The Pack Arm chair racerFirst time rider
    Sep 2009
    Clarksville TN
    175
    The bike I have needed a new sprocket when I got it. It had a 47 tooth aluminum rear sprocket, adn the only one I could find to fit was a 40 tooth rear. Well I got it today and went to install and my chain was way too long. I know the two sprockets are different diameters, and I definitly need a new chain, but how do I know what chain to buy? The only numbers I can find on the old chain are 520. I counted the links and there are 106.
    wichita KS
    16
    what kinda bike is this on?
    dirtjunkie85 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Utah
    230
    I'm assuming this is going on a 250sx as your name suggests but i would see about how many links you can overlap on the sprocket and then i would just cut that many out of the chain. chain breakers are super cheap compared to a whole new chain.
    Motorcycle chain breaker
    But if your sent on a new chain i usually get mine at the same place they also have tons of sprockets that should fit better than a 40.
    Motorcycle chain.
