Results 1 to 7 of 7
Thread: question =)
    windsor
    89
    question =)
    hey every one thanks for previous help, but this is where im at now i got my trike back and it runs like a dream and will go through all gears but when i try and go full throttle, at half throttle it starts to skip or sputter and wont go any faster, now ive been told carb but i was told by my buddy the carb if absolutely fine, so im not sure what to do now, now ANY help or ideas or input will be great guys.
    thanks, cory.
    windsor
    89
    any help??
    ilmoakw is offline At The Back Of The Pack Arm chair racerFirst time rider
    moncton
    244
    Still sounds like carb issues to me...
    Take out the jets, clean them, clean the carb and take out and clean the petcock. Make sure the gas cap is venting. BATTA BING BATTA BOOM!! Piece of cake..............
    Cleaning carbbs doesn't mean the outside or leaving jets in. This ethanol kills us if the fuel is a couple months old.
    windsor
    89
    the carb has been cleaned 3 times and soaked and every thing. im thinking its the cdi or coil or some thing
    windsor
    89
    it only messes up when i go past half way on the throttle other then that its fine and it will idle fine
    Jun 2009
    Leander TX
    2,217
    Who cleaned the carb? Did you clean it or did someone tell you it was cleaned?
    Where did you get the trike back from?
    Why was it gone?
    How long was it gone?
    Is the same gas in the tank? How old is it?
    What was changed?
    Who did the changing?
    What's your trike?
    How old is the plug?
    How does the fuel screen/filter look?
    How does your air filter look?
    How does your air intake look?
    How's the exhaust system?
    If you checked the things Dirtcrasher said and they're all good, then change the CDI and or coil.
