Results 1 to 3 of 3
Thread: need help asap.
    windsor
    89
    need help asap.
    hey every one thanks for previous help, but this is where im at now i got my trike back and it runs like a dream and will go through all gears but when i try and go full throttle, at half throttle it starts to skip or sputter and wont go any faster, now ive been told carb but i was told by my buddy the carb if absolutely fine, so im not sure what to do now, now ANY help or ideas or input will be great guys.
    thanks, cory.
    Pacific NW
    4,255
    Quote Originally Posted by yamaha guy View Post
    thanks, cory.
    welp?
    I did my carb and it was great and then it got some new crud from the tank.
    but if your carb ran great then your friend is right.
    Wind 'em up and it stutters?
    Hot coil break down?
    does it do it when cold or just hot?
    does it help if you pull on the choke? when its crapping out or does it just make it run messy
    windsor
    89
    it only does it when i rev up the engine, so more rpm, which will cause more heat, so hot coil break down sounds like a possible option.
