$250 is fair. Maier makes new white, black, and red plastics front and rear last I checked a few months ago. A little elbow grease and you can have that 200x looking nice. If you want to get the paint off the fenders (I think the front is savable at least?) Try a product called Safe Strip, it comes in a tall aerosol can. Spray this stuff on any surface, let it sit overnight, and the paint will peel right off. It is safe on plastic, as I have used it on some of mine, and it saves you a lot of time! After using this product, I remove the loose bubbled paint with a brush, then use wet sand paper (start at 200 grit) to get the rest. Good luck!
81, 85 Yamaha Tri Moto 125
83 Yamaha Tri Moto 200 x2
85 Yamaha Tri Z 250
84 Kawasaki Tecate 250
84 Honda ATC 70
85 Honda ATC 350X
84 Honda ATC 250R
(2) 84 Honda ATC 200x
82, 83 Honda ATC 185s
81 ATC 200
Lots of other parts and bikes
