Results 1 to 14 of 14
Thread: Big Red Tires Help!
    May 2009
    Minnesota
    457
    Big Red Tires Help!
    So its to my understanding that the OEM tires (25x12x9) for the 250es are still available to order and at the motoprimo by my house they show up as only $61.85??? Would these mount on to my 200e and is all i would need to do order in the tires and valve rims? Im confused, please take a look at the link. Thanks
    http://www.motoprimo.net/fiche_secti...1985&fveh=2809
    1982 Honda Big Red 200e
    1985 Honda 200x- sold
    1986 Honda 125m- sold
    1986 Honda Big Red 250es
    1,736
    the parts finder at my dealer alot of the time shows the part and price but is not available. you say its by your house, well your best bet is to go up there and find out.
    May 2009
    Minnesota
    457
    If they are available would the only things i need to order be the tires themselves and the valve rims? Why are the valve rims separate from the tire?
    Oct 2009
    Lancaster Ohio
    69
    You can buy valve stems at autozone or advanced. I just bought tires for my 250es 25x12x9 ITP mudlites from Dennis Kirk. I love them. I think $65 each and shipped super fast. And discount tire mounted them for $8 each tire, I cut off my old tires and cleaned the bead before I took it to them it may be a little more if you have tires on rims.
    1,736
    you mean the rims, well what size is your tires on there right now? if the 3rd number is 9 (22-11-9 for example) then you should be able to put those tires on the rims you have now. on those tires you got posted above (big red tires) the size is 25-12-9, 25 inches in hight, 12 in width and 9 inches is the rim size. you can add/take 2 inches in width to your stock tires normally and the last number must be the same (so the tires fit to the rims.)
    maybe im not understanding on what you mean by valve rims? lol
    May 2008
    Northwestern Ontario, Canada
    552
    Good luck with BR OEM's. They are around if you look. I tried to get one to replace a blown sidewall, was on backorder. After 2 months I gave up. I got two new rears for the price I was quoted for OEM (about 130$). I have better traction with the new tires but the ride is definetly stiffer and it seems to ride a smidge high on the end. The tires are so stiff now I can run with less than 1psi in them and they still won't fall. I may just try to order the OEM again and wait for it. At least I can ride now in the meantime!
    My Trikes...
    -1985 Big Red
    -1986 250r
    -1984 200x
    -1980 110
    -1980 ATC 185
    May 2009
    Minnesota
    457
    Quote Originally Posted by Daniel 250es View Post
    You got 25x12x9 mudlites for $65?
    dajeepman's Avatar
    dajeepman is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2009
    Dallas Texas
    207
    thanks for letting us know.. that place is the cheapest I have found them at! I'm gonna order me a set next pay check
    May 2009
    Minnesota
    457
    Ya ill be ordering a pair for sure, Thanks
    dajeepman's Avatar
    Nov 2009
    Dallas Texas
    207
    man turns out they dont have them for that price anymore!! crap i should have ordered them when I had the chance.
    bonkers_200s's Avatar
    bonkers_200s is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Middletown, NY
    393
    I just bought a full round for my red from Dennis Kirk and it was about that price per tire give or take a buck. I take my tires to a local place called tire discount center and for a few bucks a tire , they change the valves, recycle the old tires and mount the new ones.
    If you can't fix it with a , its an electrical problem.
    85 ATC 200s--Ratted out and not running at the moment
    86 ATC 200x--All stock other than the handle bars
    85 ATC 250es Big Red -- Just got new rubbers and she wants to ride!!
    04 Suzuki LTZ250 quadsport - It was a decent price and I'm a raging idiot.
    Oct 2007
    Minneapolis mn
    4,067
    Thinking of selling the mudlites and rims off of my BR to upgrade to 27s... $300 for the set, and front wheel spacer (to get it centered just right) Got one winter of plowing on them is all... PM me if interested...
    dajeepman's Avatar
    Nov 2009
    Dallas Texas
    207
    Quote Originally Posted by bonkers_200s View Post
    They went up to 78$ now.
    Dec 2009
    illinois
    1,765
    Quote Originally Posted by BIGREDGUY View Post
    The 250ES BIG RED tires are sure to mount on your 200E BIG RED, I have restored my 1984 ATC200ES BIG RED from the ground up. A few years ago I went to my local Honda dealership and ordered new tires for my 1984 200es . My Honda dealer said they were the original equipment for this model. I have recently found out that these tires might be the original equipment for the 250ES BIG RED but they fit perfectly on my 1984 200ES,. I have looked at the brochures and it seems they are similar and it seems my Honda delaer made a mistake on my OEM tires. The 250es will fit your 200E OEM rims, here is my 200ES with the tires on it. The last picture is the 200E with the correct tires, they seem some what similar to the 250ES tires I have on mine.
    Attached Thumbnails Attached Thumbnails 100_0874.jpg   100_0485.jpg   100_0474.jpg   82-200e-BRweb4_.jpg
