Thread: taking out a lug nut bolt?
    oregon
    668
    my last post i deleted so i can put pictures up for an example.
    i really need help so if you know how then help would be nice.
Name:	hub bolt1.JPG
Name:	hub bolt2.JPG
    Beaver Falls, PA
    2,666
    Are you trying to remove the stud? Heat and beat...
    oregon
    668
    k thanks.
    im hoping this will work for a 250r rear hub.
    Sabula,IA
    620
    I wouldn't beat on it. I used a press to get mine out but a good size vise would probably work. Just put a socket slightly larger than the "head" of the stud against the back of the hub, put it in the vise and press the stud into the socket.
    __________________
    '85 ATC250R
    .030 Over Wiseco
    FMF Pipe/Answer silencer
    36PJ Keihin
    K&N
    Boyesen reeds
    Magura hydraulic clutch
    Roost Boost
    MSR bars
    OMF swingarm skid
    ITP Beadlocks
    Three Wheelin' Since '84
    Ontario, CANADA
    4,538
    Quote Originally Posted by 250rAL View Post
    ditto, when I put wheel spacers on my spare 85 R I did this method with a 20 ton press. Worked great. I wouldnt beat on it either
    RPFLU member and co-owner.
    Hardtails is all we do.
    #NOLINK
    #MAKEHARDTAILSGREATAGAIN
    #SUSPENDTHIS
