83 250r troubles....
guys i have an 83 250r the problem is it does not seem to run well in the bottom 2 gears, real bogish and lots of smoke not no power band snap.... But when you ride and hit 3rd seems to clean out and run ok good...
I have put need reed's, plug, air filter, and did a compression check (got back an average just over 130)
Mix is 32-1 ...same thing i run in my cr250,
Choke does not seem to be stuck but kind of seems like that's how it runs.
Has the stock main jet (130) and seems to be the stock pilot or slow jet...
What would you suggest doing now...?
Thanks in advance.
And cool site...
//ArrowChat Integreation Code
