Results 1 to 3 of 3
Thread: 1987 Suzuki Lt 80 help. Please
    Faribault,MN
    I am replacing some clutch parts and I keep hearing that I should take out a few of my front clutch springs. Does anyone have any ideas on how to do that? Also on my rear clutch I took the cover off and the hole were the cover slides over the shaft with the splines on it spins inside the cover is it supposed to do that?
    Dec 2002
    Kansas
    2,387
    I think your wanting to remove rollers not springs. Inside the front hub is 6 rollers, I removed 3 on our old LT80's but LT80 himself says remove 2 of them so thats what I would do.
    I can't remember on the rear, its been way to long since I have been inside one.
    If you want super quick results, I would go to www.exriders.com and do a search for LT80 user name and see what he says I'm sure it has been covered.
    I had the RIGHT to remain silent, I didn't have the ability!
    LT80 is offline New to the board Arm chair racerNew to the board
    East Springfield, PA
    64
    Smokinwrench is correct, remove 2 rollers.
    Yes, the rear clutch is supposed to spin inside.
