Thread: 70cc valve size questions
    Mar 2007
    Texas
    5,045
    I'm building a racing 70cc setup. The rule state i have to keep it 70cc. meaning no boring/stroking. I found a palce that sells lots of race stuff for a 70cc. they have a race head that is what they call a big valve head.
    http://www.tboltusa.com/store/trail-...b7bdad62aa68b1
    it's 25mm intake and 22mm exhaust and the ports are bigger as well as the valve angle changed slightly. it was designed for a 88cc bigbore setup or bigger, but the guy said it woudl work on a 70. My question is what is the stock honda valve sizes? are they close to that size?
    should I get this eace setup? I'm going to buy a race piston and alloy cyclinder from the guy for sure. I need a 15:1 compresion setup if he can get it to me, but anything over 12:1 will work for now. We'll use cb16 airated race fuel (130 octaine rated if we have too.) but expect if we get it to like 13:1 100-110 octaine will work fine.
    later we will be designing a compelte EFI or electronic fuel injection system for this setup as well. So YES upgrade just will be offered which means you guys can convert to EFI!!!!
    anyway, what are your thoughts. I'm going to be purchasing parts next week.
    ________________
    https://www.mikesatvfix.com
    Oct 2007
    Minneapolis mn
    4,067
    SCHWING!!! A fuely 70!
    Mar 2007
    Texas
    5,045
    let me rephrase this, the efi kit will will be available for ANY size chinese ATV/scooter/pitbike engine size this manufacturer sells. So the 200x can be EFIed and so can the 350x.
    ________________
    Oct 2007
    Minneapolis mn
    4,067
    So could my BR!!!???? SCHWING!!!!
    Apr 2004
    Brigham, Québec, Canada
    1,528
    Quote Originally Posted by oscarmayer View Post
    Do you use an atc-70 engine? Because they are 72cc...
    1984 Yamaha YTM-225DX
    Québec 3-wheeler riders group
    Mar 2007
    Texas
    5,045
    the rules he ride in only allow up to a 70cc 4-stroke or a 50cc 2-stroke. the sad thing is the power of the 2 do NOT compair. those are factory build race bikes and engines. DRR is one of them and APEXI is another. the onyl chance I have is if they next year change the rules to make it more fair and let me run a 90cc in the class. even iwth about $1200 in motor work and efi systems, we will only get about 10-11 hp. thyse 2 strokers are running 13 or so HP @11k and can rev to 14k-15k.
    ________________
