Where can I get the needle jet for this carb part # 13 on the microfiche ? I checked service honda and it says that the part is discontinued.
you can try sudco if you know the number off the jet. There are plenty of aftermarket rebuild kits for 85 250r
I got a rebuild kit and that is the only part not included with the rebuild kits. By the way it is not the needle itself but the brass jet it moves up and down in.
That would be the main jet. You can get those at a local shop.
__________________
'85 ATC250R
.030 Over Wiseco
FMF Pipe/Answer silencer
36PJ Keihin
K&N
Boyesen reeds
Magura hydraulic clutch
Roost Boost
MSR bars
OMF swingarm skid
ITP Beadlocks
Three Wheelin' Since '84
What he is looking for is called the Needle Jet. Its what atomizes the fuel and air mixture before it goes out of the carb into the cylinder. The main jet actully screws into the bottom of it. If you need one I have the whole carb I will sell you. PM me if your interested.
Trikes
1985 Tri-Z 250 Piped ported and PV'd
1985 ATC 250R trail destroyer!
1984 ATC 70 rebuilding
1982 ATC 70 stut wheeler drag bar an cooler rack equipped
1973 ATC 70 searching for parts...
Bikes
2006 KLX110 BBR160 Super R head ported BBR Super Pro rear swingarm ect...
1988 KX500 The Beast!
1986 KX540 In search of parts!!! Help if you have some
1982 CR480 Unlimited Evo Racer
1982 CR125 Unlimited Evo Racer
1982 YZ100 cheater bike...
1981 KX250 Unlimited money pit Evo Racer
