Results 1 to 9 of 9
Thread: ATC 90 and the 56mm piston won't work. What can I do to solve the problem?
    Wisconsin
    201
    So I asked questions and did some research and ppl said that the 56mm piston kit will work on the ATC 90. I had to get a 110 cylinder, crank/rod, head bolts and timing chain. I brought the cylinder to the machine shop and they said the wall will be paper thin. So after I have all the parts now I can't do it. The 54mm piston on DrATV is probably a 14mm wrist pin. Will a cylinder off a 125m swap over to my engine? Would this solve the problem?
    1978 ATC 90
    22mm Keihin carb
    Ported intake/head
    Performance cam
    56mm 9.5:1 piston
    110 cylinder/crank
    110 cylinder/ timing chain
    Front drum brakes
    Brush guard
    Complete rebuild to a 122cc
    Complete frame off restoration.
    $1400 invested
    1983 ATC 110
    22mm carb
    Ported head/intake
    Performance cam
    56mm 9.5:1 piston
    Complete rebuild to 122cc
    $1000 invested
    1984 200x
    26 mm carb.
    CR85 rear caliper
    TRX hubs/rims
    $871 invested
    Jackson MI
    1,688
    I think you will need to sleeve the cylinder up, and then bore the case's to fit the bigger sleeve.
    83 ATC 70.
    83 Tri zinger
    ATC450AF
    86 310-R Drag racer
    Nov 2007
    ulysses pa
    1,231
    your STOCK ATC 110 cylinder will BORE OUT to use the 56mm piston. whats left of the sleeve is not actually paper thin and any one telling you this is full of crap. i have this exact set up sitting in my shed. im going to go measure whats left of the sleeve right now for you.
    Wisconsin
    201
    Much appreicated. I think I will be taking it to a different machine shop.
    1978 ATC 90
    22mm Keihin carb
    Ported intake/head
    Performance cam
    56mm 9.5:1 piston
    110 cylinder/crank
    Front drum brakes
    Brush guard
    $1400 invested
    1983 ATC 110
    22mm carb
    Ported head/intake
    Performance cam
    56mm 9.5:1 piston
    $1000 invested
    1984 200x
    26 mm carb.
    CR85 rear caliper
    TRX hubs/rims
    $871 invested
    Nov 2007
    ulysses pa
    1,231
    sorry i forgot this. you will be left with 1mm of skirt left all the way around the piston. doesnt sound paper thin to me, how about you? i think you have the right idea with going to a different machinest.
    May 2007
    Orange County, NY !
    1,672
    Nov 2007
    ulysses pa
    1,231
    Quote Originally Posted by riverrat View Post
    How many cc's will this give you?
    should be 123 to 125cc.
    Wisconsin
    201
    I came up with 122cc's. Their is a chart on DrATV.com.
    1978 ATC 90
    22mm Keihin carb
    Ported intake/head
    Performance cam
    56mm 9.5:1 piston
    110 cylinder/crank
    Front drum brakes
    Brush guard
    $1400 invested
    1983 ATC 110
    22mm carb
    Ported head/intake
    Performance cam
    56mm 9.5:1 piston
    $1000 invested
    1984 200x
    26 mm carb.
    CR85 rear caliper
    TRX hubs/rims
    $871 invested
    Wisconsin
    201
    Monday I'm calling them and asking them again what the wall thickness will be. They measured the piston at 55.9mm. My micrometer gave me 55.5. It is advertised as a 56mm piston. They didn't give me any other measurements. If they won't do it I'll take it to a different shop. They are a bit more for the same service but at least I have another option.
    If I have to I will get it sleeved. I'd rather do that then not utilize all the parts I have collected.
    1978 ATC 90
    22mm Keihin carb
    Ported intake/head
    Performance cam
    56mm 9.5:1 piston
    110 cylinder/crank
    Front drum brakes
    Brush guard
    $1400 invested
    1983 ATC 110
    22mm carb
    Ported head/intake
    Performance cam
    56mm 9.5:1 piston
    $1000 invested
    1984 200x
    26 mm carb.
    CR85 rear caliper
    TRX hubs/rims
    $871 invested
