For my 1984 big red 200es. Maier does not make any rear fenders fronts only. Am I screwed?
I am looking into the rear fenders for the 200ES BIG RED , I know there is a site that sells aftermarket rears for this model but I cannot find it yet. I will let you know when I do, I am 100% positive they are made.
I have googled and yahooed and bing'ed my head to death searching.
If you can find them, then your the man.
They were reproduced I know for a fact, there is a site that sells them, I have seen them and will let you know within the hour. I will do some searching.
I just found it! http://atcheaven.com/Reproduction.php
They are a fiberglass reproduction though, I am not sure of the quality.
Aww, shows they are no longer available. I would email them to see if they can get or make more
I have 85 200M plastic on one side of my 200ES. They fit fine. seemed to be exactly the same to me.....
R.I.P. Yamahondaman
Still practicing my NoobiX cube, take it easy on me...
1982 Yamaha YT175J ( Not much left but the's)
1982 Yamaha YT175J
1983 Yamaha YT125K + 175J =![]()
1984 ATC 200ES BR - running again - Camchain noise holding me back....
1984 ATC70 -SOLD-
If you are looking for new OEM HONDA rear fenders for the 200es big red ,there is a member on here who has both sides. "bigred72" his name is larry. He might sell them, he has a ton of stuff and he even has a new 200ES motor still in the crate from Honda!
Sweet. You must have really done some digging. I will give the a call and see what they say. Ok your the man.
THIS IS THE ANSWER I GOT FROM ATC HEAVEN IN REGARDS TO THE ATC200E 200ES BIG RED REAR FENDERS
The answer is kind of yes and no. I can't make them myself anymore because I have moved house and I no longer have a large shed to work in. I still have the moulds and it is possible I can get someone to make them for me but I see a couple of issues.
Number 1 is if I get them made will the finished product be up to a standard. Its hard to get someone else to produce something when you have a particular high standard in mind.
Number 2 is most probably the price will go up. these are a difficult and time consuming item to make, I would undoubtably have to charge more for these and given they were a very slow seller previously I just don't know if it is worth getting them done.
I have just left them up on the site to see if anyone is still interested.
Please let me know your thoughts.
Cheers
steve smith wrote:
> Do you have or can you get new rear fenders for the 1982-83 200E 84 200ES BIG RED again? You have them posted on your site but it says no longer available. item listing: RF-958-82
I would consider pursuing this if I was a purest. However I am into doing resto mods so having the exact part is not neccessary.
My question now would be, what other available fender would work with the 200es seat?
I believe the 84 trx200 rear plastics are the same as the 84 200ES... ya might find something for that...
These are for an '85
http://www.maier-mfg.com/shop.cfm?ac...modelyear=1985
