Thread: How do I lube the brake cables?
    Tulsa, OK
    27
    Hi Guys,
    I have an ATC 70, and the little brake seems very hard to pull. How can I make it easier? I'm guessing it needs to be lubricated. How do I lubricate it?
    Thanks, Matt
    1985 Honda ATC 70, and 1983 185s
    Tionesta, PA
    5,747
    You can buy a Cable Lubricator - that is the best way. they are failry inexpensive - roughly $5
    Looks like this
    cybrman's Avatar
    cybrman is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Winter Park, Florida
    254
    Are you sure it is the cable? Have you tried disconnecting it and manually moving the actuating lever to be sure.....
    It's certainly possible the cable is rusty or even frozen but I would start with the brake drum first, because that is just as likely if not more so to have some issues causing your problem.
    1985 250SX #2 300sx risen from the ashes.
    1985 200X
    1983 200
    1979 ATC70
    1985 ATC70
    1985 ATC110
    1985 Big Red
    Toronto Canada
    697
    You can buy brake cables from eBay for about $13. If it's definitely your cable(s), I would just replace them... nothing feels better than new brake cables!!
    Manitoba
    536
    Old fashioned way to lube them was to use a funnel and some plastecene clay to adapt it to the end of the cable, then pour in some light oil and wait for it to trickle down.
    84 200x
