Im gonna be getting a plastic tank for my 350x soon, and i dont want it to turn yellow because of the gas, i heard somewhere that kreem will keep it from turning yellow, but i dont know how it works, any one know, any one ever try it? thanks
1985 350x
1985 atc70
2006 ltz400
2017 z125pro
im not sure about it keeping it from turning yellow, but its a 3 part system that you get from any motorycle dealership. its just a coating that you shake around in the tank to stop the tank from leaking. so it might just work. its also white in color
Leaks, Leaks, Leaks! Why does it always have to leak!http://www.3wheelerworldforums.com/viewtopic.php?t=11559
Yeah i heard it makes another layer of protection in the tank or something like that.
1985 350x
1985 atc70
2006 ltz400
2017 z125pro
kreem is a 3 part system but the first two parts would not applly to a new plastic tank. the first part etches the metal, the second part rinses out the residu from the first part the third part is the actuall cream. the first part would eat the plastic. i definatly would not recomend it on a used plastic tank and personally would not use it on any plastic tank. i don't beleive it would adhere properlly to the plastic and would eventually flake off.
Then how would i keep a plastic tank from turning yellowish brown from the gas?
1985 350x
1985 atc70
2006 ltz400
2017 z125pro
drain it after each use.
screw that, so everytime it turns yellow im gonna have to paint it? man that sucks.
1985 350x
1985 atc70
2006 ltz400
2017 z125pro
I guess it would be less of a hassle to just pay the extra $250 bucks for a factory $420 dollar metal tank. :?
1985 350x
1985 atc70
2006 ltz400
2017 z125pro
The tank isn't going to turn yellow over night. I had a clear tank on one of my old sleds and it's had gas in it for over a year and it was only slighly yellow. The main cause of lighter colored plastic tanks turning colors is uv damage from the sun, if you don't store your trike out doors you should be fine. Using octane boosters also turns tanks colors faster.
http://photos.yahoo.com/dynofox250 (TF 03 pic's)
Trikes: Restored '86 ATC 250r, original and mint '83 185s
Quad: '86 TRX 250r
Sled: Rev X 800ho mod
Bike: '00 ZRX 1100
TF '03 and '05 Survivor
consider another color scheme? they make red plastic tanks too
85 350x
Youre using kreem in your plastic tank? has it turned an ugly color yet?Originally Posted by CHAINSAW
1985 350x
1985 atc70
2006 ltz400
2017 z125pro
So with the tank not being able to breath, stickers can go it without bubbling? How much does kreems cost?
1985 350x
1985 atc70
2006 ltz400
2017 z125pro
the 3 part kit costs about 27 to 30 dollars
