Results 1 to 13 of 13
Thread: Axle from another Honda ATC/ATV for '83-'85 200X?
    Apr 2010
    Saskatchewan
    112
    The axle on my 200x(first gen) is bent and i thought rather than straightening it i'd upgrade to a better one. Do any axles from another bike fit my swingarm?
    Tampa FL
    55
    i would like to know this also i want to widin mine
    6,809
    81-82 atc250r is direct bolt on but I wouldnt call it an upgrade unless you find an aftermarket one . I have a stock length heavy duty durablue for a 200x in stock if you like .
    Even the 86/87 200X fits in the carrier bearings.......83-85 200X and like S L said, the 81/82R fits right up. Although the 81R had a drum brake, so IDK.....
    I had an 83/84 250R axle in my 86 200X so that must fit yours too...........
    Sprocket sizes change, lock nuts and seal ID sizes for whatever axle but any of them can be made to work and yes, the sprocket lines up (may need flat head bolts though....) They almost all fit the carrier bearings though......
    I guess not many changes were made, even the 450R axle journals fit in a 350X carrier, other changes would have to be made though..... Just using an example
    Lancaster, PA
    1,738
    82 250R not 81 the drum brake changes things, but unless you find a good aftermarkrt one its not an upgrade. Durablue still makes and axle, but you have to use the 250R sprocket, that elimates the rubber dampners, and its not cheap.
    1985 Tiger 250LC
    1985 Tiger 200LC
    1985 ATC 350X
    1985 ATC 200x
    1973 ATC 70 (resto project)
    and many more!!!
    Blue Line Graphics
    6,809
    The easy old school solution for using an 81 250r axle in a 200x was to dremal out one axle carrier nut and use the other 2 to lock it down . This is how we did it back in the day before anyone made an aftermarket axle for the 200x. As DC said the drum on the 81 needs a little more room were the 82 doesnt .
    Tampa FL
    55
    how wide is the 250r compared to the 200x
    Apr 2010
    Saskatchewan
    112
    How much $$$?
    I'd also love ta see pics of the 200Xs you own!
    6,809
    Quote Originally Posted by xr132 View Post
    How much $$$?
    I'd sell the durablue for 120.00 plus shipping . Are you in the states . cant tell by your profile ?
    Here are a few pics of 2 of my 200x's , I have posted many pics before but I understand the search function is not working to great .
    Attached Thumbnails Attached Thumbnails sparks12..JPG   200x6..JPG   200x3..JPG   sparks13..JPG   sparks11..JPG
    Apr 2010
    Saskatchewan
    112
    Nice Xs! Is that(axle)new? No i'm not in the states i'm in Canada.(prolly cost an arm and part of a leg ta get it here).
    Thanks very much
    Tyler
    120$ - He's giving it away!! GET-IT!!
    I HATE being so broke NEVER have I felt this way.
    Awesome info on the 81R swap S L...................
    Woodsrider's Avatar
    Woodsrider is offline At The Back Of The Pack Arm chair racerFirst time rider
    Feb 2009
    Eastern Passage, NS
    238
    Yeah...our dollars are almost even right now too...it's a good time to buy stuff in the States !!!
    Willamstown PA
    5,820
    i have stock axles at $40 a peice...your best bet is to have a swingarm made or modified to fit in the 200x if you wanna run somthing else.
