Results 1 to 15 of 21
Thread: The Junkyard Dog lives!
    Beaver Falls, PA
    2,666
    So I dragged home this carcass from the junkyard a couple of weeks ago. Found a gas tank and seat/fenders at another junkyard, threw a 200x front wheel and cut spacers on the front, put on 200x hubs and 250r rear rims (thanks atcTim) and got some funky 70's street bike handlebars. I threw a carb rebuild kit on it, and wham! Fired right up! I don't know how long it's been sitting in that junkyard, but it's a Honda... going out to change the oil, but one quick question... it runs great but won't idle... should I move the needle clip down to allow more fuel to flow? No amount of messing with the air/fuel and idle screws makes a difference. Woohoo! another redneck toy to make the neighbors roll their eyes
    Tionesta, PA
    5,743
    Nice Matt - now you need a funky headlight for it! Try moving the needle a bit and see what happens.
    Manitoba
    536
    I would remove the carb again and make sure the idle circuit isn't plugged. A fine copper wire though the idle jet may help remove a plug, that and an aerosol carb cleaner as a chaser. Remove the idle screw as well and blow carb cleaner through it, and make sure it comes out both the bottom where it picks up fuel, and out the venturi.
    84 200x
    bonkers_200s's Avatar
    bonkers_200s is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Middletown, NY
    393
    Wow, a pile of junk to one bad @!#$% looking trike!!
    If you can't fix it with a , its an electrical problem.
    85 ATC 200s--Ratted out and not running at the moment
    86 ATC 200x--All stock other than the handle bars
    85 ATC 250es Big Red -- Just got new rubbers and she wants to ride!!
    04 Suzuki LTZ250 quadsport - It was a decent price and I'm a raging idiot.
    Beaver Falls, PA
    2,666
    Got one coming from 86trizinger... gonna be a 90 headlight with 12 volt electrics... I love it!
    Beaver Falls, PA
    2,666
    Quote Originally Posted by bonkers_200s View Post
    thanks, but I'm not done... I want this one to be all about fun... Tim, I may need help making a "Brady Bunch" sissy bar! lol
    Tionesta, PA
    5,743
    Oh yeah - we can come up with something
    hey, clean out the slow jet, very small hole.
    one cylinder is not enough!!
    Beaver Falls, PA
    2,666
    brand new carb kit, brand new fuel line and filters...
    Okanogan Co., WA
    48
    Nice lookin' trike man!! I'm gonna have to talk to the wrecking yards and see if they ever get these things!! We don't have junkyards around here unless you count everybody's front yard!! Like the part about the redneck toy makin the neighbors eyes roll, I get the same feeling sometimes...
    Beaver Falls, PA
    2,666
    thanks... everything I do to it will be bolt-on so I won't have any regrets... lol
    Feb 2009
    Rome,NY
    1,046
    i put one of the ebay carbs on my auto X man what a difference that carb makes ... i cleaned the old one real good and blew it all out and it would run ok but that new carb really made a huge difference in the idle and all over really
    Beaver Falls, PA
    2,666
    Ok... it's still alive, but comatose at the moment... I found out why it was junked. The spark plug hole is stripped. Is there an easy way to fix this without buying a bunch of special threading tools? Another possibility, would a 90 head go onto a 110 motor, or is the 110 bigger inside? I have a spare 90 head.
    Nov 2009
    1,147
    You could cross reference to old head part numbers on bike bandit to see if they are the same. Even if they are not the same I'm pretty sure they interchange.
    But here's a spark plug repair kit for only $20.
    http://www.amazon.com/Perma-Plug-1-2.../dp/B0025PMJHA
    Nice fine by the way.
    Beaver Falls, PA
    2,666
    Quote Originally Posted by 200XMichigan View Post
    Thanks for the link.... that's exactly what I was looking for!
