Results 1 to 2 of 2
Thread: 350x main jet
    p26575r16's Avatar
    p26575r16 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2006
    Reno NV
    252
    350x main jet
    Anyone know what kind of main jet the stock '86 350x keihin carb uses? I bought some a few years ago and they were not right, so I took the old one into the local honda dealer and bought some correct style ones. If I remember right the first time I picked up jets from them they looked them up by application and gave me the wrong ones. When I went back I took the old jet in to match it up. I ended up keeping the first set I bought anyway because I left them at home when I went back. The problem I am having is I threw them in the same bag and now I cannot remember which one's fit. I need to pick up some different size jets and I am at work, my trike is at home so I can't go take it out to check. I think it used the longer hex style jet, but I also have some short flatblade style jets in the package. Is it the longer hex style or the shorter flatblade style?
    Not the exact ones I have but here is an example of the hex style jet I have (similar to this one anyway): http://cgi.ebay.com/ebaymotors/Keihi...Q5fAccessories
    '86 350x
    '05 sportsman 500 (the couch)
    p26575r16's Avatar
    Nov 2006
    Reno NV
    252
    Also, anyone know where I should start when jetting it for 4000 feet? It is 12:1 compression, .50 overbore, cobra exhaust, uni air filter, stock air box with lid, stock cam, strong valve springs. I have a 138 in it now which worked good for the stock setup. I also have a 145 and a 155. I was going to pick up a 150, 160, 165, and a 170. Thank you
    '86 350x
