I bought the rocky piston kit for atc 110 + 4mm off of ebay. I went to install it and it snapped in half. Does anyone know where I can get one? I have contacted the seller of the piston but I was hoping I could find it sooner then later.
1978 ATC 90
22mm Keihin carb
Ported intake/head
Performance cam
56mm 9.5:1 piston
110 cylinder/crank
110 cylinder/ timing chain
Front drum brakes
Brush guard
Complete rebuild to a 122cc
Complete frame off restoration.
$1400 invested
1983 ATC 110
22mm carb
Ported head/intake
Performance cam
56mm 9.5:1 piston
Complete rebuild to 122cc
$1000 invested
1984 200x
26 mm carb.
CR85 rear caliper
TRX hubs/rims
$871 invested
i got my full set for 10 bucks. the dealer seems to be selling the one after another, id just buy the whole kit again. 10 bucks aint bad, its just a bit time consuming
I called the dealer and asked. They only had oversizes for the 125 up to .5mm. So 55.50mm won't work. Can you elaborate on what you got and from where?
1978 ATC 90
22mm Keihin carb
Ported intake/head
Performance cam
56mm 9.5:1 piston
110 cylinder/crank
Front drum brakes
Brush guard
$1400 invested
1983 ATC 110
22mm carb
Ported head/intake
Performance cam
56mm 9.5:1 piston
$1000 invested
1984 200x
26 mm carb.
CR85 rear caliper
TRX hubs/rims
$871 invested
He's talking about just buying another kit just for the oil ring . Those 1 piece oil rings are a pain to put on and their is ax a trick to doing it .
http://cgi.ebay.com/ebaymotors/ws/eB...EF:MOTORS:1123
I know that they are brittle to begin with. I was being very carefull and it still snapped. Very frustrating. I have emailed that seller through ebay about my problem. Hopefully I will hear something back soon.
1978 ATC 90
22mm Keihin carb
Ported intake/head
Performance cam
56mm 9.5:1 piston
110 cylinder/crank
Front drum brakes
Brush guard
$1400 invested
1983 ATC 110
22mm carb
Ported head/intake
Performance cam
56mm 9.5:1 piston
$1000 invested
1984 200x
26 mm carb.
CR85 rear caliper
TRX hubs/rims
$871 invested
yep, thats it
http://cgi.ebay.com/ebaymotors/HONDA...s#ht_500wt_956
