Thread: what options for oil do i have- 86' 350X
    QCR77's Avatar
    QCR77 is offline Just Too Addicted Arm chair racerJust too addicted
    Aug 2009
    SA TX
    538
    i have been running the same valvoline 4 stroke motorcycle motor oil with the wet clutch additives. this is the same oil i would run in my 110 and 200es. my question is basically, what should i NOT run. can i run a 50 weight fully synthetic? do i need the additives for a wet clutch? im trying to find the best oil to stick with. it has to be affordable though, cause i change it alot. i like the idea of a fully synthetic if i can get away with it. what do ya'll run?
    QCR77's Avatar
    Aug 2009
    SA TX
    538
    i been digging around the internets and i have read to only use motorcycle oil and ive also read about people that use regular motor oil. also some use deisel oil? i just need to change it today so i thought i'd ask before i went to the parts store
    PA
    3,515
    I only run valvoline vr-1 racing oil 20-50
    This is one of the few oils Harley recomends in it's bikes.
    WWW.HREATV.COM
    QCR77's Avatar
    Aug 2009
    SA TX
    538
    Quote Originally Posted by SWIGIN View Post
    ok thanks. thats regular motor oil right?
    Baltimore, MD
    6,088
    I try to run oil made for bikes. I don't like the synthetic oils. If you change oil alot, I think the cheaper motorcycle oils would be good for you. I also like the 20w50 or straight 30 weights. Clean oil and clean oil screens and filters beat fancy oils any day in my book.
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    QCR77's Avatar
    Aug 2009
    SA TX
    538
    yeah, thats what i figured. just thought i would ask. i ended up at a different parts store than usual and they had a different kind than my normal so i grabbed it. castrol 4t . seems to run good
