Results 1 to 13 of 13
Thread: Why is my 200s atc smoking really bad
    Apr 2010
    Canada
    Hello I havent ran my atc in about 4 months and when i took it out to run again it started in about 8 to 10 pulls i let it idle for about 30 seconds to a min and then i took the atc for a slowride just to get 'swarmed up and while I was doing that when i got to higher RPM'S it started smoking not black but like a white color but it has lots of power and idles great and doesent smoke when it idles not to sure why i stored it indoors and i put new gas and cleaned the carb please help thanks
    Feb 2009
    michigan
    2,387
    white smoke is usually oil,black is usually a richness problem,did i just make up a word,lol.
    1985 ATC 250R
    . Team Red Trike
    Feb 2006
    north of buffalo
    557
    It's probably smoking due to peer pressure. What grade is it in?
    Runners:
    84 200s
    05 rancher
    12 rancher
    texas
    567
    rings could have possibly rusted a little bit im thinking
    ilmoakw is offline At The Back Of The Pack Arm chair racerFirst time rider
    moncton
    244
    Quote Originally Posted by dickieg89 View Post
    Hahahaha I just spit coffee all over my desk...
    Feb 2006
    north of buffalo
    557
    Quote Originally Posted by ilmoakw View Post
    Jim Rome makes fun of people who do that, he's kind of a Pen i$.
    Runners:
    84 200s
    05 rancher
    12 rancher
    May 2009
    Minnesota
    457
    Time for new rings perhaps?
    1982 Honda Big Red 200e
    1985 Honda 200x- sold
    1986 Honda 125m- sold
    1986 Honda Big Red 250es
    1986 Honda 250sx
    Mar 2007
    Texas
    5,045
    the smoking is probebly caused by a dirty old carb. if it sat for that long, I owuld take the carb apart and clean it up. modern fuels after abotu 1-2 months tend to start varnishing up and thic an cause things to run bad. white smoke is an indication of water int he system. did you leve it outside? maybe water got into the fuel system. also if the fuel went bad it could cause the same issues, again, take the carb off, clean it and put fresh fuel in the thank. this would be my first start along with a new plug for good measures.
    ________________
    https://www.mikesatvfix.com
    Pacific NW
    4,255
    smoke motor
    wow
    did it sit in the sun shade sun shade like condensation in the gas tank?
    and then emulsified the moisture with some new alcohol gas.
    That alcohol acts like the additive 'heet' and can 'burn ' the water gas
    if the rings did get stuck, I'd imagine some mystery oil in the cyl, spin it and let it sit, do compression check and run it the way they love to run..with slight attitude.
    if somethng serious is wrong, it prob wont make it worse.
    Richland WA
    808
    ITS WORRIED ABOUT OBAMA CARE.
    SMELL the exhaust, does it smell like fuel? Ive seen excess fuel look white out the pipes.Click image for larger version.
    tundrawolf is offline At The Back Of The Pack Arm chair racerFirst time rider
    High desert, CA
    176
    Quote Originally Posted by TeamGeek6 View Post
    ITS WORRIED ABOUT OBAMA CARE.Click image for larger version.
    Unfortunately, because it is an old ATC, the death panel, er, I mean the governmental efficiency board has decided to give it standard octane gas and make no repairs. Let the ATC rot, a newer quad can use the parts that would have gone to it.
    Richland WA
    808
    LOLOLOLOLOLOLOL (except it aint funy...)
    which is why im stocking up on ATC parts AND doctors right now.Doctors are hard to find that work under the table, but theyre out there.
    Apr 2010
    Canada
    okay ill try cleaning the cab again with carb cleaner and ill flush the tank and throw a new plug in to
