Results 1 to 7 of 7
Thread: Dead in the water
    Aug 2009
    lancaster PA
    100
    Dead in the water
    My KLT 185 likes to Die when I try and make it go through water. The first time it happened was 2 weeks ago I was dared to go through the "mud pit" I hit it hard and fast 3rd gear down to 2nd and made it through and the thing died. 5mins Later Started right back up! Last weekend tried it in slowmo 2nd gear to first and it left me stranded right in the middle of it. Pushed it out and started it a couple mins later and rode away.
    Why is it doing this to me?
    Lucky for me the water is only 1ft to 1 1/2ft deep
    BackRoadRacer
    KAWI KLT185
    Custom crap spray paint Job
    Stock Harley 1200 Sportster Can
    SUZUKI TL1000S
    bone stock for now
    Yamaha Blaster
    Pro Circuit Header & Can, Pro X Piston, Uni Filter
    Tionesta, PA
    5,744
    you have an electrical connection / component that is not water tight - could be lots of different ones - first one that comes to mind is spark plug wire / cap - could have a slice in the wire or a bad rubber grommet where it fits over the plug.
    Aug 2009
    lancaster PA
    100
    You know that should of been the first thing that I thought of. Duh thanks ATCTIM now what am I gonna do? Guess try and make some waterproofed wire connections
    BackRoadRacer
    KAWI KLT185
    SUZUKI TL1000S
    bone stock for now
    Yamaha Blaster
    Tionesta, PA
    5,744
    pack your connections in grease (inside and out) then coat them with black tape tightly! This is an old trick of Mud Truck runners.
    bonkers_200s's Avatar
    bonkers_200s is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Middletown, NY
    393
    Get your plug wire wet, get someone else that you don't particularly care for to hold it, kick/pull start the machine, if they yell, you're getting water in between the boot and plug wire and the spark is traveling the path of least resistance.
    My X used to do the same thing after riding in the snow for awhile.
    If you can't fix it with a , its an electrical problem.
    85 ATC 200s--Ratted out and not running at the moment
    86 ATC 200x--All stock other than the handle bars
    85 ATC 250es Big Red -- Just got new rubbers and she wants to ride!!
    04 Suzuki LTZ250 quadsport - It was a decent price and I'm a raging idiot.
    cox's Avatar
    cox is offline Just Too Addicted Arm chair racerJust too addicted
    Aug 2009
    Edmonton alberta canada
    552
    FTMFW!! did this to my 4runner..... Mmmmm mud
    and bonkers_200s, that is not very nice LMAO!!!
    R.I.P. Yamahondaman
    Still practicing my NoobiX cube, take it easy on me...
    1982 Yamaha YT175J ( Not much left but the 's)
    1982 Yamaha YT175J
    1983 Yamaha YT125K + 175J =
    1984 ATC 200ES BR - running again - Camchain noise holding me back....
    1984 ATC70 -SOLD-
    Aug 2009
    lancaster PA
    100
    I packed all my connectors with white lithium grease and took it right through that killer mud hole. Hopefully I will get someone with a camera so I can post a pic or 2 from next weekends ride.
    BackRoadRacer
    KAWI KLT185
    SUZUKI TL1000S
    bone stock for now
    Yamaha Blaster
