Well finally picked up the trike this week. It was advertised as a Honda Trike with engine capacity of .11 so figured it was a 110 but now its home the frame says atc90, so figure its a 90, They are the same as a 110 anyway right?
She's had a rough little life and is missing some bits. And its yellow, looking under the tank and plastics revealed it was red once upon a time.
Bits missing or need replacing
Chain Guard (my kids are little and don't want misshaps with chains as have seen them before and are nasty!)
It has no Seat/plastics latch
Plastics/Seat are chocked up underneath with wood, is this where a toolbox would sit?
No Neutral indicator am sure I can make something if I want
No front Guard, Think I have found one near by pretty cheap.
So far checks have found
No spark - Points open etc but will have to check this out more
Tank doesn't look rusty inside from what I can see
Tested the brake and it locked up so probably needs adjusting and lubing up
The H/L gearbox I can't seem to move the lever.
Whats the button on the side of the carby you pull out for? its just in front of the choke?
Rear tires are not the same and while they both say 22x11x8 one is obviously wider and a little taller than the other.
So I was hoping I could ride it as is when I got it hope so the kids could enjoy but looks like I might just have to start stripping her back straight away.
Will be repainting frame and redoing the wiring harness I think as there are alot of small bare patches and other dodgy connectors etc. I think I am going to get rid of the light will see how it performs but think I might just get a torch mount and mount a damn good cree up there for night time rides/hunting.
anyway going to be alot of fun.
Ryan
