So I have a set of plastic coming this week and I ordered up some repro decals. Does anyone have any tips or tricks to get them on smooth with no bubbles underneath.
Alcohol to clean the plastic, then spray the back of the decal with water. That's how I apply graphics.
83' ATC70
85' ATC70
83' ATC200x
96' TRX90
05' CRF50- The only thing left that hasn't been modded out are the engine cases.
use a bondo spreader on it whilst applying to reduce bubbles afterwords.
You will cry, you will scream if you've heard half the **** I've seen.
Are you gonna get up and burn an X in your head?
"Cut throught the bone and cut through the wire"
Trikes:
84&85 Tecates
85 R
85 X
Support Scrapthraher Customs!!! Home of the Three Wheel Outlaws! PM me if you need a head rebuilt, valves cut, head milled or lapped!!!!!
Credit card will work also. Applying graphics is kinda like farting in a public setting. Sometimes it goes off without a hitch. Sometimes you're work is shameful.
83' ATC70
85' ATC70
83' ATC200x
96' TRX90
