Results 1 to 10 of 10
Thread: anyone else have this problem?
    1,736
    my 1984 atc110 runs great, starts first pull without even giving it gas if i put the choke in the sweet spot. it runs perfect. but when its running low on gas it wont idle very long. it runs fine when riding it but when i come to a stop it will idle maybe 5-10 seconds then die. the gas level is well over the bottom of the gastank drain hole. once i refill the tank it runs perfect again. its only when the middle of the tank is completely exposed. its almost like the gastank needs the weight of all the gas for it to flow properly, but it runs fine when its on the throttle...
    i plan on doing a fix up on the tank soon and im not to worried. im just wondering what your ideas might be. its weird
    Nov 2008
    ontario
    1,055
    could be the float in your carb out of adjustment
    proud owner of a trx300ex quad and an 85 atc 70
    Apr 2010
    Huntington Beach, CA
    177
    i was having what seemed to be a similar problem to yours but with my brothers old TTR125. We cleaned out the carb jets and it seemed to run a lot better. But before it was cleaned it would only idle for short period of time with less than 1/4 tank of gas. Hope that helps!
    Jan 2005
    RI
    2,530
    your petcock screen could be clogged and with the less fuel, there is less force pushing the gas through the filter.
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    1,736
    Quote Originally Posted by DeePa View Post
    thats what i was thinking, but dont you think it would get worse when i give it gas, since the engine is demanding even more gas than at idle and the flow cant keep up even worse.
    May 2009
    Minnesota
    457
    Try opening up the pilot screw on the carb 1 or 1 1/2 turns
    1982 Honda Big Red 200e
    1985 Honda 200x- sold
    1986 Honda 125m- sold
    1986 Honda Big Red 250es
    1986 Honda 250sx
    yater is offline Just Too Addicted Arm chair racerJust too addicted
    Jun 2003
    Tyler, Texas
    672
    Check the gas cap vent too. When you refill the tank, you're also venting it. Next time, try removing and replacing the cap without adding fuel. Just a thought.
    1,736
    Quote Originally Posted by yater View Post
    i took the cap off to check for gas when it was doing it.
    Sep 2007
    100mi west of Chicago
    3,582
    Is the petcock on reserve when this happens or still set to ON?
    Rob
    1,736
    its turned to the on position, lol i never thought of using reserve. that might be it. im seeing the reserve level slosh around at the bottem. lol ill try it when i get home.
    EDIT- next time im low on gas, lol
