Results 1 to 4 of 4
Thread: 200s engine break in
    PAPA250r is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2009
    greentown PA
    389
    whats a good procedure to break in a rebuild 10:1 honda 200s ? fireing it up tomorow nee dsome tips thanks !
    84 200s almost done
    84 atc 70 project
    Feb 2009
    Rome,NY
    1,046
    I allways just ride like you normally would .. make sure you vary your throttle and no wot runs to top speed for a few trips then change the oil and you should be good to go
    Willamstown PA
    5,822
    same, im on my 4th hour, gonna ride an hour tonight and then change oil then go at it WOT
    6,810
    Depending how tight you had it bored but I always bring the motor up to temperature and let it cool off completly . Do this procedure a few times and your good to go . Also change the oil after about 2/3 hours of running . Also check the oil after a few min of run time , the dry top end will use up some of the oil and it might be a bit low .
