If it ran that low on oil, I'd sure be looking at my cam journals if I were you.
Even a "low" oil level was always an issue for the 200X and 350X and a seized cam makes it very tough for the engine to turn freely.
If it has BALLS from 0 to 1/2RPM I would also be looking at the carb but unless stuff got plugged (your filter did fall off partially) I can unly see the needle clip falling out and it's done it to me.........
BALLS without a load are different from BALLS under a load........
Thatt filter let some crap in so entirely disassemble the carb and clean out every orifice and jet.
