Thread: 1979 atc110 dumb carb question
    chula vista
    72
    hey guys i cleaned out my carb really good with help from my neighbor now im trying to adjust it he told me something about turning one scre 1 1/2 and the other being the idle i dont remember and hes not aaround can you guys please tell me how to adjust? my car looks like this one but mine is stock i labled the scres #1 and #2 thank you
    "Never look down on someone, unless your helping them get back up"
    haggard 2hundie's Avatar
    haggard 2hundie is offline Would rather be at the front of the train than Arm chair racerJust too addicted
    muscatine, iowa
    764
    just a guess but id say #2 is your idle screw and #1 the pilot screw ? that might be the one that need s 1 1/2 turns out after its lightly seated then adjust your idle screw check the post labeled throttle stop screw, the post is on a 200x so there may b differences but it may help, like i said just a guess as im new to the mechanical side of this.
    ailll1's Avatar
    ailll1 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2009
    Québec
    405
    1- is the pilot screw which as to be 1 1/2 out when sitting like 2Hundie said
    2 is the idle screw i think in means a higher idling out a slower idling
    usually setting the pilot screw is pretty simple
    get your engine hot then, adjust the idle speed 1400rpm if my memory is good
    after screw the pilot screw in until it stalls
    back it out 1/4 of a turn
    restart it up
    readjust the idle
    should be running good
    but, again, the best way to adjust it its to try things and mess with it
    1985 ATC250sx
    1984 ATC200s
    1984 ATC200x
    HONDAS FOR LIFE!!!
    Nov 2009
    1,147
    One is dead center on the cylinder portion of the carb, that sets the idle speed. The other screw is the air/fuel mixture screw.
    chula vista
    72
    ok and whats the proper way of adjusting both?
