Results 1 to 8 of 8
Thread: exhaust header pictures 200es
    texas
    567
    can anyone take a picture of there ehader olted up to the engine? i can get mine to mount in flush and im havin trouble pulling the engine to get this done. does there have to be a tight seal there? i know ehaust leaks are bad but how bad?
    Manheim, PA
    5,817
    Look at the online schematics, www.bikebandit.com
    texas
    567
    those dont show it bolted up to the motor. thats the first place i looked. i just need to know if the plate that holds the header on has to have no gap between the engine and it.
    Apr 2009
    Saskatchewan
    119
    No, every one of my three 200es have a gap between the plate and the engine. The gasket squishes some to make the seal as far as I know.
    Sep 2007
    100mi west of Chicago
    3,582
    Yes just make sure you have the copper colored gasket in there and tighten the 2 nuts to spec. There will be a gap between the plate and the head.
    Rob
    Apr 2009
    Saskatchewan
    119
    Thats what I meant also no there shouldn't be no gap between.
    ailll1's Avatar
    ailll1 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2009
    Québec
    405
    watch out not to tighten them too much
    i broke 1 bolt in my 200s, it was a pain to remove
    1985 ATC250sx
    1984 ATC200s
    1984 ATC200x
    HONDAS FOR LIFE!!!
    texas
    567
    hm. it doesnt seem like mine is even capable of the "no" gap option. maybe its because im using bolts instead of studs because they broke? as of now its not acting like there is an exhaust leak as no smoke is coming out of that area so it seems to be good.
