Results 1 to 4 of 4
Thread: 200es electric start
    Apr 2009
    Saskatchewan
    119
    Hopefully there isn't a thread already about this problem if there is I couldn't find it. I have a 200es that I bought with a bad battery so I put a new battery in it and it makes a rough grinding noise when I use the electric start and won't start. When I push the throttle to start it pretty much stalls out the starter completely. It starts great with the rope but not with the starter I did a bench test on the starter and it is working fine. I know it had really high compression when I tested it maybe that could have something to do with it. I tried to use the compression lever when starting and it turned over smoother but I didn't have a third hand to give it some gas. Wondering if anyone could point me in the right direction to figure this out. I also checked the teeth on the starter gears and they are all fine. Thanks
    1,736
    check for bad connections and bypass the cilinoid to see if thats the problem too.
    1,736
    texas
    567
    that problem is most likely your starter solenoid. mine does that when i have a loose connection on the battery. fix your battery connections and youll be up right away.
