I have a 250r that needs some engine parts, I'd rather drop in a CR480 engine. I found one for $200 that is an 82.
Will this work? I was hoping to get the adapter mounting plates from bigbore if he still sells the kit.
Thanks
Thanks
82 and 83 had the same motors just dif chassis.
Alright, I will get an 82 or 83 engine then, thanks
82 has a 4 speed transmission and 83 has the 5 speed.
Trikes
1985 Tri-Z 250 Piped ported and PV'd
1985 ATC 250R trail destroyer!
1984 ATC 70 rebuilding
1982 ATC 70 stut wheeler drag bar an cooler rack equipped
1973 ATC 70 searching for parts...
Bikes
2006 KLX110 BBR160 Super R head ported BBR Super Pro rear swingarm ect...
1988 KX500 The Beast!
1986 KX540 In search of parts!!! Help if you have some
1982 CR480 Unlimited Evo Racer
1982 CR125 Unlimited Evo Racer
1982 YZ100 cheater bike...
1981 KX250 Unlimited money pit Evo Racer
I picked up the 82, came with the frame/350x front end. The rear end is a trike swingarm I believe. Maybe 350x?
Wish it was 5 speed, but i figure it will still be plenty fast, at least faster than the 250r engine
