Page 2 of 2 FirstFirst 1 2
Results 16 to 28 of 28
Thread: Penetrating oil test
    Phoenix, AZ.
    6,719
    I'm wondering if the PSF/Acetone mix will hurt paint... Somebody try it and let us know.
    Silver Creek, NY
    86
    Acetone will certainly eat paint, I know from experience, lol. Didn't seem to hurt pc though.
    2006 LTR 450-Dasa, PC3, Fuel Intake, much more...
    1991 Blaster-3 Mill Stroker, Flotek Ported, F7, Head Shaved, Flywheel lightened, VF3, 35mm PWK, much more...
    1984 200X-Work in progress
    1985 Tecate-also work in progress
    Apr 2002
    s.w. michigan
    6,498
    I think acetone is the stuff to remove finger nail polish ain't it ???
    I have my project frozen up crank soaking. Piston rings being treated to Kroil.
    this is that 75 dollar project 175 Yamaha I picked up last week.
    I had to press the jug off the piston (after soaking with Kroil), worst case frozen up motor I have ever dealt with.
    Hey, that acetone is sorta pricey ! 8.95 plus tax a quart.
    I bet that GM product is VERY good too.
    Apr 2004
    Brigham, Québec, Canada
    1,529
    Somebody told me water was just as good to free rusty nuts than penetrating oil... I'll have to try the home-brew mix!
    1984 Yamaha YTM-225DX
    Québec 3-wheeler riders group
    COLORADO
    685
    the thing with water is that it takes forever, like a day or more. The ATF/acetone mix works faster than anything, especially when mixed with FIRE! propane for small stuff, oxygas for the real heavy stuff or the non precise stuff.
    You will cry, you will scream if you've heard half the **** I've seen.
    Are you gonna get up and burn an X in your head?
    "Cut throught the bone and cut through the wire"
    Trikes:
    84&85 Tecates
    85 R
    85 X
    Support Scrapthraher Customs!!! Home of the Three Wheel Outlaws! PM me if you need a head rebuilt, valves cut, head milled or lapped!!!!!
    I find Oxy/Acet to remove nearly anything........ But, sometimes you don't want the heat to take off paint and or coatings. Bt, usually when something is that seized, the rest of the "moving/sliding" parts are seized too...
    Does ANYONE recall the brake fluid post?? or did I read that elsewhere??
    Regardless, heat does the trick. It was 400$ for a complete set of braising/cutting/heating torches and right up there with the best $$ I ever spent!! Along with the MIG welder and 20 ton press
    PA
    3,515
    The old boys over on the lathe site I go too all seem to mix there own out of ATF and acetone.
    WWW.HREATV.COM
    COLORADO
    685
    Yeah, my machinist at cididit.com (lonnie) uses it all the time. He says he has used more oxy-acet. heat since he found out. He also thinks Kroil is the greatest thing since sliced bread too.
    Trikes:
    84&85 Tecates
    85 R
    85 X
    Woodsrider's Avatar
    Woodsrider is offline At The Back Of The Pack Arm chair racerFirst time rider
    Feb 2009
    Eastern Passage, NS
    238
    Is this what you are thinking of ? http://www.3wheeler.org/vb/showthrea...highlight=rust
    Mar 2009
    new england
    1,391
    Saw the same test on a machinist site that I follow. Similar results. Diluted tranny fluid is cheap and turned out to be best. The downside is application. Spray cans are so easy. I keep a few oilcans charged and some pb for the underneath work
    Billy Golightly's Avatar
    Live Oak, FL
    15,070
    A few years ago I seen a place (I think it might have been Eastwood?) that sold a rechargeable aerosol can. You just filled it up with your contents, and then pressureized it with your air compresser. That'd be an ultra slick setup for this mixture.
    Jackson MI
    1,688
    I like Zep 45 as a penetrating (Lubricant). But FREE ALL Is one of the best I have seen work on rust.
    83 ATC 70.
    83 Tri zinger
    ATC450AF
    86 310-R Drag racer
    COLORADO
    685
    The bad thing with Zep is it seems to evaporate quicker. I like the older stuff when they used VYDAX instead of PTFE. Is free all still in business?? I will try that.
    also Billy, ZEP makes a rechargable canister as well as Sure-Shot, they work great.
    Trikes:
    84&85 Tecates
    85 R
    85 X
