Your best bet if you are stick with a 125 cylinder and piston is to get an 84 or 85 yt125 carb and a nicer airbox used off of ebay or a board member and do that. If you are going with a 175 set up, then you need to get the whole top end and carb and airbo and fuel pump off the 175 and use those. You will need the 175 ehaust pipe too. If you are using the stock 125 pipe, then there really is no use for anything other than a stock late model carb.
Nicholson 500x (Project)
Nicholson 185s
PK Racing Suspension 70
A+ Inc Suspension 70
AWS Aluminum 90 frame
