in 1st and 2nd no problems but in third i get the feeling that the clutch isn't out all the way and it just gets worse and worse in 4th and 5th. any thoughts, i'm open to all suggestions
Your clutch is slipping. It's time for new fiber plates and maybe new springs.
Rides:
1982 ATC70 (Lifan manual 125)
1987 LT80 (piped, widened)
My feedback thread
RIP Trace.. Godspeed.
Had the same problem with my 83x. Only third gear though. Turned out my third gear in the tranny was chipped really bad causing slippage. Felt like a clutch problem at first, but it only did it in third. Changed the oil and found all kindsa shavins. Third gear shavins.
'85 Honda 200X
'85 Honda Big Red 250es
'85 Honda 250R
'82 Honda ATC 70
'87 LT500R Quadzilla
BRUP!!!!!!!!
clutches slip in all gears when going bad.most likely you have worn gears and bushings in the tranny.
1985 ATC 250R.Team Red Trike
