Results 1 to 14 of 14
Thread: How much psi to put in a rear shock?
    Tbcoplin is offline At The Back Of The Pack Arm chair racerFirst time rider
    Oct 2009
    Hammond, la
    157
    Question How much psi to put in a rear shock?
    Anyone know how much nitrogen to put in a rear shock on my tecate? I weigh 210 lbs
    84 Big Red- User
    85 250SX- clean
    85 200X- mint- < 10 hrs on it
    85 350X- Mint- <40 hours on it
    86 350X- mint- <40 hours on it
    2-85 tri-z's- Both frame off restorations
    84 250R- Mint- <15 hours on it
    86 250R- Super clean- < 30 hours on it
    86 500R- Sick fast!!!
    86 Tecate 3- Frame off restoration- Mint
    86 Big Red- Mint- <30 hours on it
    Madrid/Spain
    127
    The book says between 142-213 psi and that the factory setting is 142 psi.If I remember right mine is around the lower range and Im around your weight,doesnt bottom out,seems fine.
    PA
    3,515
    I normally go 165psi.
    WWW.HREATV.COM
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,244
    the nitrogen charge has no effect on bottoming out,,, all the nitrogen does is pressurize the oil to prevent foaming ,,,,
    volfan537240 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Eufaula, AL
    292
    ok. im a noob. where do you put the nitrogen and oil in?
    85 tri-z (in pieces)
    421 cub banshee
    ^ Its not that simple unfortunately......
    MOST OEM Service Manuals will walk you through it, but it's not like changing oil in a car. You have to entirely disassemble the shock, clean it, change any worn parts (seal head and seals, maybe the bump stop) and then bleed the air out of it. Then you can use the schrader valve on your resevoir (albeit directly connected to the shock or a remote resevoir....) to finish the job by adding nitrogen.
    Anyhow, your best bet is to spend some time with the BOOK and or read up an articles found on the internet that show what to look for, whats gone wrong for other 1st timers, and how it's done properly..........
    You also have to make certain that the chrome shaft looks GREAT! and it has to be straight, that requires a set of V-blocks and a dial indicator. Which is allot of stuff most guys do not have but anyone in the family or your friend network should have what you need!
    If you can get it DOWN! then you can save yourself allot of cash and many shops will only charge 10$ for the 1$ of nitrogen the use to pressurize it. If it's bouncing, then the damping is shot most likely because it is low or out of oil. A welding shop with gas (Oxygen/Acetylene/Nitrogen/CO2/Argon etc etc) may be willing to fill it as it takes nearly NOTHING to fill it up
    Good luck!
    Last edited by Dirtcrasher; 04-30-2010 at 02:06 PM. Reason: spelling............................................
    Eufaula, AL
    292
    the main reason i am asking is because i want to disassemble mine to polish it but i didnt know how to get the oil/nitrogen back in. thanks Dirtcrasher.
    421 cub banshee
    ^ No need for oil or nitrogen then.......
    Just loosen the compression nuts all the way and OFF and there will be a giant "C" clip that comes out, then the spring can be removed and you can polish away!!
    Not ALL shocks, but many of them can be done this way......
    The book should show that too, where's your book!!
    s. louisiana
    38
    If you still need your shock filled I can help I'm in Lacombe.
    Eufaula, AL
    292
    my manual is at home. im at work now lol.
    the hydraulic fitting is at the top and will prevent the nuts from coming off from the top. i was wondering if the shaft unscrews from the bottom also. then i can disassemble it frm there.
    421 cub banshee
    Well, since I have NO IDEA what shock you have, I must assume it's a Banshee? the one in your signature??
    Good god...................
    Anyhow, USUALLY you can loosen them enough to get out the C-ring, did you EVEN try YET?? Or are we still wasting bandwith??
    If it's a Banshee, I'd suggest another website and not 3 wheelerbansheeworld.com
    Eufaula, AL
    292
    no its a tri-z and no i havent tried yet since im still at work. ill be here all night.
    and i dont ask banshee questions on here. i ask those questions on bansheehq and bansheecentral.
    421 cub banshee
    Feb 2008
    Orange County California
    726
    ^^^^^Dude, sweet to see you here!!!!!!^^^^^^
    Listen to these guys, they will do you right! It is where I go for info....
    1986 ATC250r
    1984 ATC70
    Eufaula, AL
    292
    thanks auto. sweet avatar lol!
    421 cub banshee
