Thread: honda atc 90 (need help)
    st. paul, mn
    4
    I found out my 1978 Honda atc 90 has a 54mm piston in it and was wondering if stock 90cc head gasket will work with the over sized bore and piston? also when adjusting valves if you don't have a .002 feeler gauge is there a general rule for adjusting the valves correctly or close enough?
    Nov 2009
    N Hollywood/ CA
    588
    climes,
    Welcome, indeed stock head gasket should not be problem when using an oversized bore & pistons. I would recommend a feeler gauge evertime. Is your bike running at the moment for checking the valves?
    st. paul, mn
    4
    no my bike isn't running right now. i have the engine disassembled I was thinking about throwing a bigger piston in because of its inefficient top end speed in 4th gear only to find out it already had a larger piston installed. After finding that out I decided to clean every thing up replace all gaskets and check the condition of valves, piston, cylinder wall, and I lapped my valves while i had taken apart. My valves are way off now because I accidentally measured them to .020 with a feeler gauge, oops. My bike wouldn't idle no matter what air fuel mixture I had the carburetor set at do i need a bigger carb for that piston or could it be just a timing issue? The new head gasket im trying to install over laps the cylinder about 2mm all the way around but you think it shouldnt be an issue?
    st. paul, mn
    4
    Thanks for the quick reply earlier and the free advise it is greatly appreciated.
    st. paul, mn
    4
    trying to get this trike ready for mud fest
