Yeah, Ive worked on a few, I would check every jet and compare with altitude, check the needle as well. Those carbs are built kind of sketchy from the start. Good luck on your Aermacchi.
You will cry, you will scream if you've heard half the **** I've seen.
Are you gonna get up and burn an X in your head?
"Cut throught the bone and cut through the wire"
Trikes:
84&85 Tecates
85 R
85 X
Support Scrapthraher Customs!!! Home of the Three Wheel Outlaws! PM me if you need a head rebuilt, valves cut, head milled or lapped!!!!!
