Page 3 of 15 FirstFirst 1 2 3 4 5 13 ... LastLast
Results 31 to 45 of 215
Thread: Project ATC 110 All tricked out ! Video !!!!
  1. #31
    Aug 2005
    Lockport, NY
    2,395
    Mike - Can you break out EXACTLY what is needed for this conversion...? I have some BUYING to do. This is what I want for my motor.
  2. #32
    6,808
    For the tranny conversion all you need is a sl90 tranny shaft + sprocket and a new custom 20x37mm shaft seal which I purchased mine from a local store called Florida bearing , all the atc tranny gears work on the sl shaft .
    The sl90 clutch conversion is a 1969 sl90 complete clutch set up , you will need all the internal parts to do the conversion . You will have to cut your atc90 or 110 shifter shaft flush with the inner cover as it doesnt need the extera length for the auto setup anymore .
    If you need anymore details let me know .
  3. #33
    6,808
    Oil pump shaft for a stroker App
    Here ya go DC . Pics of the oil pump shaft trimmed for a stroker application .
    Attached Thumbnails Attached Thumbnails 110motoroilpump1.JPG   110motoroilpump.JPG
  4. #34
    Ripley Tn
    1,363
    look at what I just scored Hum theres a part number to im gonna call the local honda shop tomorrow and see if they can still get the part you never know
    http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWNX%3AIT
    85 Atc 70
    86 Atc 125m
    85 atc 350x
    86 atc 250r
    86 Atc 250r TT build
    85 Big Red bought brand NEW
    2012 Honda Goldwing Gl1800
  5. #35
    Feb 2003
    Australia
    927
    You want to be careful. There was a couple of different shafts from back in the day and one didn't work out.
  6. #36
    6,808
    Quote Originally Posted by greenhuman View Post
    Very interesting , I havnt run into that problem yet . Thanks for the info .
  7. #37
    6,808
    Little more done
    Had a little bump in the road . I went to hone the cylinder and it had a few to many pits so it's bored out to 56mm now . Instead of the pk cam I'm going with a #93 grind Kenny Harmon roller bearing cam which has a little more lift and alot more duration than the PK cam .
    Attached Thumbnails Attached Thumbnails 110motor5555.JPG   110motor555.JPG   110motor55.JPG
  8. #38
    Visalia, CA
    720
    Cool would ever think of selling this bike? And how many cc's is this going to put out?
  9. #39
    6,808
    Quote Originally Posted by Shorty View Post
    Everything has its price LOL . 56mm bore X 61.5mm stroke = 151cc
  10. #40
    6,808
    Motor Done
    Got the motor pretty much completed just need a new set of points and polish up the cover . Going threw my recoils and found a Bandito brand one in chrome so I gave it a rebuild , it should complement the bandito frame nicely . The cut out hi/low cover went on with no problems . I purchased this custom cover from Tommy Gaian a few years ago and finally got a chance to use it .
    Attached Thumbnails Attached Thumbnails 110motordone3.JPG   110motordone.JPG   110motordone1.JPG   110motordone2.JPG
  11. #41
    Aug 2004
    Cedar City, Utah
    474
    Right On! So the worlds coolest 110, just got cooler. The temp just dropped a couple degrees in florida! Youre gonna prove Al Gore right if you keep it up! HH
  12. #42
    6,808
    Quote Originally Posted by HondaHarry View Post
    Thanks HH ,
  13. #43
    6,808
    Buttoned Up
    Added all the final touches to the motor this morning . BAPP shorty intake , 24mm Mikuni race carb , Vented dipstick , NOS shifter , exhaust studs , Installed the points cover but still need new points , On order .
    I guess its time to put it in the frame and see if it Runs LOL .
    Attached Thumbnails Attached Thumbnails 110done.JPG   110done1.JPG   110done3.JPG   110done2.JPG
  14. #44
    1,736
    looks awesome, its nice to see someone else go with a 56mm piston, im not the only one lol let me know how it holds up once you take it out for a while. i cant wait for mine, this wait is killing me, 3ish more months and i can start. lol and ill be sure to get to you about some parts as we talked about before. i cant wait to see it all done shortline, this thing is sweet
  15. #45
    Ripley Tn
    1,363
    I found a sl 90 clutch cover all i need now is a clutch pack and im going mannul
    85 Atc 70
    86 Atc 125m
    85 atc 350x
    86 atc 250r
