Page 2 of 15 FirstFirst 1 2 3 4 12 ... LastLast
Results 16 to 30 of 215
Thread: Project ATC 110 All tricked out ! Video !!!!
    6,798
    I can't stand it anymore....... SHORTLINE: Has to be one smart MO-FO to have saved all these parts all these years!! I'm really feeling ill.........................
    This will be so awesome - what better words describe it....
    Yet you still mow the lawn, trim the hedges take care of the lawn......????? I'm lost......
    You crack me up DC . I'm sure your sitting on a pile of goodies to .
    6,798
    Opened her up
    Got a chance this morning before the kids and wife woke up to tear the motor apart . Found lots of previous owner build mistakes but nothing terrible . Nice very usable 55mm pop up piston , old school PK racing cam shaft , very nicely ported head , correctly turned down oil pump shaft for stroker application , Nicely signed Helm & Son 61.5 stroker with nice and tight bearings still .
    Attached Thumbnails Attached Thumbnails 110motor5.JPG   110motor4.JPG   110motor3.JPG   110motor2.JPG   110motor1.JPG   110motor.JPG
    squirrel1182 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Derry, Pennsylvania
    253
    nice build ill be watchin it also.
    6,798
    More progress
    Got the center cases cleaned up and started putting it back together . Installed the sl90 tranny shaft so no more high /low set up , this also requires a special tranny seal 20 x 37 x 7 , the stock atc110 and sl90 seal doesnt work . Gonna use a NOS set allen bolts as an upgrade also . Next step is to tackle the clutch side .
    Attached Thumbnails Attached Thumbnails 110motora.JPG   110motorc.JPG   110motord.JPG   110motorb.JPG
    Nov 2009
    N Hollywood/ CA
    588
    Shortline10: your like Charles Bronson in his movie "Mr. Majestic" your a smooth opertor brotha. Like someone said, your a bad MO-FO in a good way of course.
    Ripley Tn
    1,363
    Ive gotta find a a sl90 motor
    85 Atc 70
    86 Atc 125m
    85 atc 350x
    86 atc 250r
    86 Atc 250r TT build
    85 Big Red bought brand NEW
    2012 Honda Goldwing Gl1800
    6,798
    Manual sl90 clutch installed in ATC110 bottom end
    Installed the mod shifter shaft , clutch with new plates and NOS clutch cover today . Used a 26mm freeze plug with a little epoxy to cover up the kicker shaft hole in the clutch cover . Coming along very nicely . Tomorrow I might tackle the top end .
    Attached Thumbnails Attached Thumbnails 110motorDD.JPG   110motorAA.JPG   110motorBB.JPG   110motorEE.JPG   110motorCC.JPG
    Visalia, CA
    720
    Shortline the next time when I visit my uncle in South Florida I'm gonna haft to drop off my 200x and my atc 110 at your house so you can mod and over haul them. LOL.
    Tionesta, PA
    5,745
    Hey Shortline - what do you use to degrease / clean the old cases - they look pretty good.
    6,798
    Tim ,
    The secrete is a soft brass brush and any type of degreaser works . I like formula 88 or for the really tuff stuff just plain old gunk .
    I'm surprised you didn't pull the head studs/dowels and run a nice stone over the base gasket area before assembly? Regardless, fantastic work but "par for the course" for you SL!!
    Whats with your comment about the oil pump being correctly turned down for a stroker? Seemed like the way you worded it that it doesn't "have" to be done but it's the right way to do it. Whats the deal on that? I'm just curious......
    Is that your kid helping you out? Projects like this are certainly one way to keep kids out of trouble
    Awesome progress! I wish you had some "Big Al's" for the 86/87 200X. Thats the machine I still need to give you a call about sometime, just wanna pick your brain!; Which reminds me that when my PC went KAPUTSKI, I lost your email and phone number. Hit me up again if you could please My email addy is in my sig............
    Ripley Tn
    1,363
    this bike is gonna ture out really nice
    85 Atc 70
    86 Atc 125m
    85 atc 350x
    86 atc 250r
    6,798
    I guess I should have taken pics of the oil pump shaft LOL . The stroker crank causes clearance issues from the rod being so far out on the cranks turning radius which causes it to interfere with the oil pump shaft . The back side of the connecting rod sticks out farther than the crank itself thus trimming the oil pump shaft a few MM's is needed on the big strokers . I believe the 58mm and smaller strokers their is no trimming needed.
    Will send you my info again .
    6,798
    [QUOTE=Is that your kid helping you out? Projects like this are certainly one way to keep kids out of trouble [/QUOTE]
    Yep thats my oldest brat age 7 just upgraded her to a atc110 over the weekend and she did great on it so the trizinger is gonna sit till my 3 year old boy is old enought to ride it .
  15. #30
    IDK if I said it, but if you have trouble getting that odd rubber coated seal, give me a yell! And thank you for your info again
