Got a chance this morning before the kids and wife woke up to tear the motor apart . Found lots of previous owner build mistakes but nothing terrible . Nice very usable 55mm pop up piston , old school PK racing cam shaft , very nicely ported head , correctly turned down oil pump shaft for stroker application , Nicely signed Helm & Son 61.5 stroker with nice and tight bearings still .
 At The Back Of The Pack
						Arm chair racerAt the back of the pack
						nice build ill be watchin it also.
Got the center cases cleaned up and started putting it back together . Installed the sl90 tranny shaft so no more high /low set up , this also requires a special tranny seal 20 x 37 x 7 , the stock atc110 and sl90 seal doesnt work . Gonna use a NOS set allen bolts as an upgrade also . Next step is to tackle the clutch side .
Shortline10: your like Charles Bronson in his movie "Mr. Majestic" your a smooth opertor brotha. Like someone said, your a bad MO-FO in a good way of course.
 Check my feedback before dealing with me
						Roostin Away
						Roostin Away
						Ive gotta find a a sl90 motor
85 Atc 70
86 Atc 125m
85 atc 350x
86 atc 250r
86 Atc 250r TT build
85 Big Red bought brand NEW
2012 Honda Goldwing Gl1800
Installed the mod shifter shaft , clutch with new plates and NOS clutch cover today . Used a 26mm freeze plug with a little epoxy to cover up the kicker shaft hole in the clutch cover . Coming along very nicely . Tomorrow I might tackle the top end .
Shortline the next time when I visit my uncle in South Florida I'm gonna haft to drop off my 200x and my atc 110 at your house so you can mod and over haul them. LOL.
Hey Shortline - what do you use to degrease / clean the old cases - they look pretty good.
I'm surprised you didn't pull the head studs/dowels and run a nice stone over the base gasket area before assembly? Regardless, fantastic work but "par for the course" for you SL!!
Whats with your comment about the oil pump being correctly turned down for a stroker? Seemed like the way you worded it that it doesn't "have" to be done but it's the right way to do it. Whats the deal on that? I'm just curious......
Is that your kid helping you out? Projects like this are certainly one way to keep kids out of trouble
Awesome progress! I wish you had some "Big Al's" for the 86/87 200X. Thats the machine I still need to give you a call about sometime, just wanna pick your brain!; Which reminds me that when my PC went KAPUTSKI, I lost your email and phone number. Hit me up again if you could pleaseMy email addy is in my sig............
						Roostin Away
						Roostin Away
						this bike is gonna ture out really nice
85 Atc 70
86 Atc 125m
85 atc 350x
86 atc 250r
I guess I should have taken pics of the oil pump shaft LOL . The stroker crank causes clearance issues from the rod being so far out on the cranks turning radius which causes it to interfere with the oil pump shaft . The back side of the connecting rod sticks out farther than the crank itself thus trimming the oil pump shaft a few MM's is needed on the big strokers . I believe the 58mm and smaller strokers their is no trimming needed.
Will send you my info again .
[QUOTE=Is that your kid helping you out? Projects like this are certainly one way to keep kids out of trouble [/QUOTE]
Yep thats my oldest brat age 7 just upgraded her to a atc110 over the weekend and she did great on it so the trizinger is gonna sit till my 3 year old boy is old enought to ride it .
IDK if I said it, but if you have trouble getting that odd rubber coated seal, give me a yell! And thank you for your info again
