Results 1 to 3 of 3
Thread: carburator repair
    haggard 2hundie's Avatar
    haggard 2hundie is offline Would rather be at the front of the train than Arm chair racerJust too addicted
    muscatine, iowa
    764
    carburator repair
    sorry no pics but the lug in the carb that aligns with the barrel is loose causing it to shift back and fourth causint the sleeve/barrel to bind up which i believe is causing my carb to load up and become flooded , can this be fixed ? j b weld maybe ? i have another carb on order but would like to salvage this one for a spare am i s. o. l ?
    Richland WA
    808
    Clean the metal carefully and use JB Weld, just make sure to bake it at 120 degrees F to harden it. JB turns to concrete if baked.
    muscatine, iowa
    764
    thank you now for the lug what is the correct position ? about how much of the lug should be exposed inside the carb mine looks like it may have had a small chunk break off of the lug if this is the case where would that broke piece have gone ?
