trying to dial in my motor, I am DOING PLUG CHOPS on the 35MM PWK but currently I can't get any top end -I went from a main jet of a stock 160 to a 165-got better but way lean.Went to a 168-170 all lean, plug white,no brown at all.I am using V-FORCE reeds with the stuffer installed,fresh motor on stock 70mm Wiseco, 13-42 gearing.I am currently on the 2nd groove from the top on the needle, (it was on the 4th from the factory)AND NOW HAVE A 175 main in there.The plug chop was better, but still in my opinion lean,there is a very small burn pattern on the porclein but IMO not dark enough.Idle to 1/4 throttle pulls right through-1/4 to 1/2 throttle same, tire comes off the ground in 1st through 3rd gears,1/2 to 3/4 same pulls right though,3/4 to top end it just flattens out, this all leads me to think the main is too small, but I am at a 175 already, that seems big-any ideas?
