knocked down the top end to find the connecting rod looking like this. is it time to split cases?
Rides:
1983 suzuki alt50
1985 honda 200x
Don't worry about the discoloration. That doesn't mean too much. The thing you want to look for is up and down play in the rod. Side to side play should be minimal but there should be a least a little. If there's not up and down play on the crank pin then you're probably fine.
The deep cut in the closest crank wheel looks kinda odd. Can you get another angle of a picture?
alright thanks, i checked for play and there wasnt any accesive play, i just was worried about the discoloration beeing so close to the crank like it got real hot. and the endine was locked upw hen i first got it but i think that was just the rusty cylinder.
Rides:
1983 suzuki alt50
1985 honda 200x
I saw the colour the opposite way, blue on the bottom, when I spun a bearing on a Dodge.
84 200x
check with the manual on here to give clearances, if either left or right or up down clearance is out replace it or rebuild it do not take the chance by any means, I threw a rod on my two stroke stand up jet ski 30 minutes after I bought it thankfully it did not crack the cases, it is far cheaper to replace or rebuild the crank than to wait for one to fail trust me I am speaking from experience.
its fine, all that i see look that way. Its play up and down you need to be worried about. Knocking on a 200x is normally the cam chain slapping. You should replace the chain and slides while you have it apart.
Rides
85 ATC350X
85 ATC200X
^^^Yes the discoloration is normal. The shims usually come apart with the connecting rod bearing first. I agree with erics350x. My x also slapped the cam chain when i first got it. If the play on the crank is in tolerance don't mess with it, but definitely new slides and cam chain since you balls deep in it!
Hey, What other dangerously fun vehicles can I Cram in my 2and1/2-car shop? (Garage.)
