How in the heck does this thing come off? I have the brake cover removed and all my Clymer manual says to do is 'slide the drum off'.
This thing must be fastened some how. Obviously it rotates with the axle. I don't see anything on the axle or in any manuals that shows how its attached.
The brake pads are full disengaged as well. This has me stumped.
Thanks in advance.
EDIT. Problem solved through carefull use of a 20 ton shop press.
Reason: Problem solved.
