Thread: Aircooled DG Gold head help.
    nitrodude81r is offline Check My Feedback before dealing with me Arm chair racerNew to the board
    Jun 2009
    Addison,Michigan
    63
    I just purchased a DG sunburst head for my 81 R. The head is painted black, I was wondering if anyone knew a way to remove the paint and not remove the gold anodized finish underneath. Any help would be appreciated, thanks.
    TF 09, 10, 11 Survivor
    81 250R- DG pipe,DG silencer, DG head, DG boost bottle, 34mm flatslide carb, UNI filter, Works shock, Nasa +5 axle
    85 Tecate-
    , but Airfoolers RULE!!!
    Worcester, MA
    1,117
    Cannot be sure on how to remove, sandblasting/acetone would likely remove both the paint and anno.
    But I'm curious as to what the head had over stock. Never heard of one til now?
    Southern MN
    1,875
    The DG gold head had bigger fins over stock to assist in cooling. It also had a slightly shallower dome to increase compression a bit. You could always restore the head to original by having it anodized gold again, that would be the way to go if you want it to look the way I think you do. Im not sure how much it would cost...
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    COLORADO
    685
    Dupli-Color makes Metalcast that imitates the anodizing look, Idk if its high heat, but looks very good and matches well.
    You will cry, you will scream if you've heard half the **** I've seen.
    Are you gonna get up and burn an X in your head?
    "Cut throught the bone and cut through the wire"
    Trikes:
    84&85 Tecates
    85 R
    85 X
    Support Scrapthraher Customs!!! Home of the Three Wheel Outlaws! PM me if you need a head rebuilt, valves cut, head milled or lapped!!!!!
    Oven cleaner will probably remove both, but you could leave it on a few minutes, wash it off and see whats up............
    I'd just repaint the prick myself unless it's a garage queen. It probably got RODE and the anodizing may be in rough shape, maybe thats why he painted it.
    THANK YOU 3WW for hitting "ENTER" when I hit TAB. It's getting sickening, BUT, I still love the board
    Worcester, MA
    1,117
    If you need it annodized later on, a dust finish on a part that size should only run you $20 or less. I used to get things anno'd all the time when I built custom paintball guns. Polished finish may be a little more unless you polish it yourself first.
