Results 1 to 7 of 7
Thread: How to clean or polish lower portion of forks?
    Feb 2005
    Canada
    663
    How can i clean the lower portion of my forks. Can i use steel wool or sand paper to polish the aluminum? Is that safe? Thanks
    1984 Honda 250R
    1985 ATC 250SX
    1985 Tri-Z 250
    1983 Honda 250R
    1986 Honda 350X
    1983 Yamaha Tri-Moto 175
    1983 Honda Big Red 200
    1981 Honda ATC 110
    COLORADO
    685
    Use a buffer with red rouge and It will look almost like chrome and be polished to near ultimate sheen. Just use a loose sisal wheel.
    You will cry, you will scream if you've heard half the **** I've seen.
    Are you gonna get up and burn an X in your head?
    "Cut throught the bone and cut through the wire"
    Trikes:
    84&85 Tecates
    85 R
    85 X
    Support Scrapthraher Customs!!! Home of the Three Wheel Outlaws! PM me if you need a head rebuilt, valves cut, head milled or lapped!!!!!
    Feb 2005
    Canada
    663
    im assuming red rouge is a metal cleaner? so should it be a soft buffer or something with some grit?
    1984 Honda 250R
    1985 ATC 250SX
    1985 Tri-Z 250
    1983 Honda 250R
    1986 Honda 350X
    1981 Honda ATC 110
    Apr 2010
    KC, MO
    64
    I say 3m rust/paint remover tool wheel then blue magic if you can find it
    COLORADO
    685
    the rouge is somewhat abrasive and works far better than any other method, you could also use a buffer on a low speed air sander. I would finish it with Mothers Mag & Aluminum polish on a Scott Shop rag. Itll look like new. It can also take pitting off as well.
    Most sisal wheels are just a sewn cloth and are fairly cheap, just dont skimp on the rouge. start with the red (basic) and progressively move to Jeweler's Rouge (white) for a mirror shine.
    Trikes:
    84&85 Tecates
    85 R
    85 X
    Oct 2007
    Minneapolis mn
    4,067
    Just do like I did, and send them to G-king here on the boards....
    http://www.3wheelerworld.com/showthr...gkingpolishing
    Manitoba
    536
    You can also get scotchbrite wheels that will get it 90+% there, and finish with the jeweller's rouge. The scotchbrite has the abrasive built in. I know it works great on bronze and will get it shining like gold.
    84 200x
